http://www.awesomestyles.com/phpbb3-styles/demo/astrum
Im looking for the edit files for the latest portal also my forum is update to version 3.0.8 the portal is showing on my forum but not compleet because i need to edit the style files.
http://www.swt-clan.be/forum/
Astrum Style
Re: Astrum Style
I'm not sure but the style might not be wide enough for the Portal.
Anyhow, try using using the prosilver edits. As far as I can see, the prosilver edits should work on this style.
Re: Astrum Style
Ive tryed but i cant find every line that must be edit.
Re: Astrum Style
Marc wrote:I'm not sure but the style might not be wide enough for the Portal.
You can find all rows in the install.xml.------>portal_docs/install.xmlSwT-CarbonzZ wrote:Ive tryed but i cant find every line that must be edit.
Only this one line is not in the overall_header.html:
Re: Astrum Style
Ok it works fe now problem solved
Thx for the help
Thx for the help
