Your Portal Version:board3_portal_1_0_6
Boardlink: http://ubermpower.co.uk/uberv2
PHP Version: 3.0.8
MySQL Version: MySQL(i) 5.0.77-log
changed image.cfg and site logo in subsilver2 and altered some things in another style.....
replaced .cfg and image files with originals / refreshed style / purged cache
Hi...
For some odd reason the layout of the portal in subsilver2 is all over the place, only things i've done was to edit some files in another style and i changed the site_logo and cfg file in subsilver2 so my site logo was on there and unless it was messed up previously and i hadn't noticed it was after i done this the layout broke!
Sorry i cant be more specific than that but i've replaced all the original files but without any joy, would be most grateful is someone could have a look and see if they can work out what the hell i've done to it!
Many thanks in advance
MT
Subsilver2 page layout messed up
- phpBB.com User: MadTaffy
Reason: fixed incorrect link
Re: Subsilver2 page layout messed up
You have installed the wrong _block_config.html.
Take the original _block_config.html for subsilver2.
How the hell did i mange that
trying to think if i've actually made any changes to that file ....hrrrmmm D'oH!
Anyway all back to normal, glad someone knows what they are doing lol, many thanks archivar... you da man
Cheers MT
Cheers MT
