CA Halcyon / Dark Blue / Green
This config works for both Styles / Diese Konfiguration funktioniert für Styles: CA Halcyon / Dark Blue / Green
open: styles/ca_halcyon/template/portal/_block_config.html
replace with:
Öffne: styles/ca_halcyon/template/portal/_block_config.html
Ersetze mit:
<!--version $Id: _block_config.html v1.0.6 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '{$CA_BLOCK2_START}' -->
<!-- DEFINE $LR_BLOCK_H_R = '{$CA_BLOCK2_START2}' -->
<!-- DEFINE $LR_BLOCK_F_R = '{$CA_BLOCK2_END}' -->
<!-- DEFINE $C_BLOCK_H_L = '{$CA_BLOCK2_START}' -->
<!-- DEFINE $C_BLOCK_H_R = '{$CA_BLOCK2_START2}' -->
<!-- DEFINE $C_BLOCK_F_R = '{$CA_BLOCK2_END}' -->
