help hiding blocks from none regged
ominae
Post by ominae »
Your Portal Version: vr 1.0.6
Boardlink: http://afterdark.thedraconian.co.uk
I have used the search on this site and google to try and find a solution
even looked arround myself
i have played arround wit a few files killed the board a few times in the prosess...
nothing much more.
i am trying to hide some of the blocks shown on my portal so that only
registerd members can see them after they have logged in to there accounts.
one is the mumble Block that is made using the ACP custom block
the other is the reent posts block.
i am not sure iff this is poss but i hope it is, i know how to disable the blocks
by omiting them from one of the cinfig files "sorry dont member the file name"
is there a mod for this or some edit i have to do i am not shy about messin with the
code though i undersand very lill.
many thanx
mark
Re: help hiding blocks from none regged
Look here:
viewtopic.php?f=31&t=1829&p=25677#p25677
You use Google to translate the text into English.
ominae
Post by ominae »
the post you linked is on about setting groups
not meaning to be dum but how dose that help me out :S
i dont get it sorry
mark
Edit; i read the whole post now thought google is nto too good it gives me an idear, they go on to talk about portalview
is this a mod i need to install to use this option to hide blocks as i do NOT have this and no idear what it is realy :S
Open styles/*yourstyle*/template/portal/portal_left.html or portal_right.html or portal_center.html
Find the blocks you want to hide from not registered users and then put this around the block:
ominae
Post by ominae »
chears dude
din realise it was that easy :)
Dimond :)
thanks
mark
