Your Portal Version: 1.0.6
Boardlink: http://sonyreaderboards.com/
I just discovered that if I'm in my portal which is http://www.sonyreaderboards.com/portal.php and I hit portal again in the menu, I get a 404 error because the page can not be found. The reason is because if I click portal on the menu within portal I get http://www.sonyreaderboards.com/forums/portal.php; it's adding a /forums to the address and my portal is outside the forum. When I'm within the forum, and click portal the address is correct, it's just doing that if I'm in the portal. What do I need to change to fix that without affecting anything else? All the links within the portal works fine.
Need Help With Portal Root Path
Re: Need Help With Portal Root Path
I figured it out by going to include/functions and making U-Portal path ./../../portal.$phpEx
