Portal Does Not Show On All Styles
meevil
Post by meevil »
Your Portal Version: 1.0.6
Boardlink: http://www.nfortress.com
Installed Board 3 from fresh.
Nothing, as I'm completely at a loss of what to do.
I've made my own themes for my forum, but for some reason none of the files for Board 3 are being copied into them automatically. Instead, all files specific to mods are just being installed into the Prosilver theme.
For example I installed Board 3. It works fine on my Prosilver theme, but does not work on my new custom "nfortressdefault" theme. I edited all of the .cfg files within the custom theme. Have I done something wrong?
I used Automod to upload the mod, and I have the most up to date version of PHPBB
Please help! :)
Re: Portal Does Not Show On All Styles
Look here:
viewforum.php?f=39
meevil
Post by meevil »
It's a custom style I developed myself.
Someone said on PHPBB that I had to configure the Mod to install on the custom styles manually?
Depending on what the style your style is based (i.e. prosilver) you'll have to do the prosilver or subsilver2 edits.
meevil
Post by meevil »
Thanks! It works perfectly :)
Return to “Styles Support”
