Images instead of text links
Mess
phpBB.com User: Mess
Post by Mess »
Your Portal Version: 1.0.6
Boardlink: http://www.hb-eu.com
Hiya,
I would like Images instead of (or above) the text links back to the original posts from the portal.
How would I go about adding this picture:
For the Warhammer Online forum, and another for the StarCraft II one?
Any ideas? Maybe its possible to use the forum image?
Mess
Re: Images instead of text links
Post by Mess »
Anyone please? :)
jerkstore
Post by jerkstore »
I would also like to know how to add images to the actual "Links" block instead of text.
Mess
Post by Mess »
Anyone know if this is possible, please? :)
Mess
Post by Mess »
Anyone able to help with this please? :)
gamingboard
phpBB.de User: gamingboard
phpBB.com User: gamingboard
Post by gamingboard »
Here is a idea:
Use at your own risk. It worked on my test forum
Open: portal/block/announcements.php
Find:
'FORUM_NAME'			=> ($forum_id) ? $fetch_news[$i]['forum_name'] :
Add-before:
'FORUM_ID'			=> $forum_id,
Open:
/styles/your_style(prosilver)/template/portal/block/announcements.html
Find:
<!-- IF announcements_row.FORUM_NAME -->{L_FORUM}: <strong><a href="{announcements_row.U_VIEWFORUM}">{announcements_row.FORUM_NAME}</a></strong><!-- ELSE -->{L_GLOBAL_ANNOUNCEMENT}<!-- ENDIF -->
Replace with:
<!-- IF announcements_row.FORUM_ID == 99 --><a href="{announcements_row.U_VIEWFORUM}"><img src="your Warhammer Online forum img" title="{announcements_row.FORUM_NAME}" alt="{announcements_row.FORUM_NAME}"/></a><!-- ELSEIF announcements_row.FORUM_NAME -->{L_FORUM}: <strong><a href="{announcements_row.U_VIEWFORUM}">{announcements_row.FORUM_NAME}</a></strong><!-- ELSE -->{L_GLOBAL_ANNOUNCEMENT}<!-- ENDIF -->
To add another image using the following code:
Find:
Add-After:
Note:Replace 99 with the forum number where you want to have a picture (viewforum?f=99)
<!-- ELSEIF announcements_row.FORUM_ID == 99 --><a href="{announcements_row.U_VIEWFORUM}"><img src="your other img" title="{announcements_row.FORUM_NAME}" alt="{announcements_row.FORUM_NAME}"/></a>
Mess
Post by Mess »
Thanks a lot mate, ill test it out asap. :D
