[DONE] pro_ubuntu
Styles Anpassungen / Aufträge bitte hier veröffentlichen.
Styles adjustments / requests, please post here.
H4Mm3r
[DONE] pro_ubuntu
Post by H4Mm3r »
I would like to adapt the pro_ubuntu templates on your portal mod... could you help me ?
Link for the theme:
http://forums.phpbb-fr.com/base-de-donn ... 57907.html
Link for my forum:
http://g33kland.fr
Thanks a lot.
Re: pro_ubuntu
Did you try to use the normal prosilver instructions on that style?
H4Mm3r
Re: pro_ubuntu
Post by H4Mm3r »
Yes I did, but on the Portal, the different blocs (normal and compacts) haven't any border... So I tried to replace the file by the prosilver's files, and only the normal blocks have a border (as you can see on www.g33kland.fr)... I just want to have some borders on the compacts blocks on the two sides... Do you see what I mean ?
Thanks for your answer.
Re: pro_ubuntu
You've installed an old portal. For the old portal we do not provide instructions.
Your blocks are of 2008-05-18.
For Board3Portal v. 1.0.6 and style pro_ubuntu based on phpBB v. 3.0.7 I can try to write a guide in a few days.
EDIT:
pro_ubuntu Style Download: http://forums.phpbb-fr.com/base-de-donn ... 57907.html
I do not want to write a great leader.
You can use the instructions for prosilver.
Only two changes need to be different.
in the root/pro_ubuntu/template/overall_header.html:
1) do not look this:
The search here:
2.) change in the root/pro_ubuntu / template / portal / _block_config.html:
look here: viewtopic.php?f=44&t=2870
Refresh your Styles:
Sorry for my bad English.
Reason: Link für _block_config.html geändert
H4Mm3r
Re: pro_ubuntu
Post by H4Mm3r »
Thanks a lot for your answers, it works fine !!!
Return to “Style requests”
