green vision v3.0.7 style
Styles Anpassungen / Aufträge bitte hier veröffentlichen.
Styles adjustments / requests, please post here.
COWBOY
Post by COWBOY »
only reference i found was viewtopic.php?f=39&t=1890&p=12497&hilit ... ion#p12497
but that was posted in 09 ... style was updated 3/10
download site for green vision v3.0.6 http://www.phpbb.com/customise/db/style/green_vision/
download site for green vision 3.0.7 http://www.cosa-nostra-design.com/en/navigation.php#2
Style has been released for the latest phpBB version.
my forum with green vision v3.0.7 and phpBB http://gearheadoffroadclub.com/forum/
Re: green vision v3.0.7 style
I will try for the style in the coming days, a guide, for incorporation into the portal to write.
EDIT:
For the style green_vision v. 3.0.7:
Except for the overall_header.html follow the install.xml.
Search in root / styles / green_vision / template / overall_header.html:
            <div class="inner">
                <li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li>
            <ul class="linklist leftside" style="background: #B8D52D;">
                <li class="{S_CONTENT_FLOW_END}<!-- IF S_USER_LOGGED_IN --> rightside<!-- ENDIF -->"><!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ELSE -->{CURRENT_TIME}<!-- ENDIF --></li>
                <!-- IF U_MCP --><li>{CURRENT_TIME} <br />[&nbsp;<a href="{U_MCP}">{L_MCP}</a>&nbsp;]</li><!-- ELSEIF S_USER_LOGGED_IN --><li>{CURRENT_TIME}</li><!-- ENDIF -->
replace:
            <div class="inner">
Detailed instructions for all, in the language English and in German, follows.
COWBOY
Post by COWBOY »
That's fantastic !!! Image
now if i can only get the AutoMod to work i will install Board3 portal Image
i did get home page to look like the green vision http://gearheadoffroadclub.com/
thanks for the quick response ..
COWBOY
Post by COWBOY »
paart 2
quick fix ...all the .html files are not in the green_vision folders
so you have to find them in public.html>(phpbb3}>styles>prosilver >template( & theme) >portal
it was like 25 files i installed them to
public.html>(phpbb3}>styles>green_vision >template( & theme) >portal
or you can refresh your site in green vision and the erors will come up one at a time took me 3 hours to get site up
then refreshed style in APC and woew it looks great
THANKS FOR THE GOOD START .. if you need i can get all the file names i moved
Return to “Style requests”
