upgrade 1.0.2 to 1.0.6
mitch
phpBB.com User: mitch1063
Post by mitch »
What is the best way to upgrade the portal from 1.0.2 to 1.0.6
Is there a way to do it or should I upgrade version by version 3,4,5, then 6
Re: upgrade 1.0.2 to 1.0.6
You will have to update from 1.0.2 to 1.0.3 and then from 1.0.3 to 1.0.6. The instructions are inside the contrib directory of the download package.
mitch
Post by mitch »
Marc wrote:You will have to update from 1.0.2 to 1.0.3 and then from 1.0.3 to 1.0.6. The instructions are inside the contrib directory of the download package.
Excellent thanks for the fast reply
