Your Portal Version: n/a
Boardlink: http://www.teamcrusade.co.cc
I installed board3portal (No other addon besides pbwow)
Hello, I am wandering which board3portal works with phpbb 3.0.5 the Reason I have that version is, it is the latest version that supports "pbwow" and pbwow had support built into it, for board3portal, I was wandering which version I would use with that + phpbb 3.0.5? I attempted the latest version and it came out in portal.php as a blank page, which led me to believe it is not supported in the prior version of phpbb.
NOTE: I uninstalled board3portal, so you will not see that error on the site, I am just wandering what version I should use with phpbb 3.0.5
i have phpbb 3.0.5
- phpBB.com User: vampirictorch
Re: i have phpbb 3.0.5
I think Board3 Portal 1.0.4 should work with phpBB 3.0.5. Just take a look at the release topic.
