1BlackOut
1BlackOut
This config works for both Styles / Diese Konfiguration funktioniert für Styles: 1BlackOut
_block_config.html
<!--version $Id: _block_config.html v1.0.6 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt style="margin-top: -2px; height: 14px; width: 140px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><span class="corners-bottom"><span></span></span></div></div><div style="height:2px;"></div><div class="panel bg3"><div class="inner"><span class="corners-top"><span></span></span>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul><span class="corners-bottom"><span></span></span></div></div><div style="height:2px;"></div>' -->
<!-- DEFINE $C_BLOCK_F_R = '<br style="clear:both" />' -->
no
Reason: Code für _block_config.html geändert.
