Language: French - fr
Version: Board3 Portal 1.0.6
Author: Anywhere91 - zone-bf.com
File to decompress the root. Add the folder language/fr/mod
/!\ Archive modified on 09/23 /!\
view last post
7ZIP Version => http://www.zone-bf.com/Telechargements/ ... only_fr.7z 10Ko
WINZIP Version => http://www.zone-bf.com/Telechargements/ ... nly_fr.zip 15Ko
TAR GZ => http://www.zone-bf.com/Telechargements/ ... _fr.tar.gz 10Ko (added 09/23)
[French - fr] Translation for Board3 Portal 1.0.6
Topic author - Translator
- phpBB.com User: Anywhere91
- phpBB.de User: fanfanb
- phpBB.com User: fanfanb
Re: [French - fr] Translation for Board3 Portal 1.0.6
Missing .com after zone-bf in links
Bonjour / Soir
Hooooooppppppsssss Sorry, going too fast
Fixed
Other problems? Contacted me by private message or my website
Regards
Fixed
Regards
- phpBB.com User: MultiUser
Hi @ll,
thanks so much, very good Board & translation
Do you have some tutorial in french for the install ?
Best regards
Best regards
. : Danke für Ihre Arbeit : .
The file install.xml in French is available on the portal to help French-language phpbb on the following website:
http://forums.phpbb-fr.com/base-de-donn ... 53702.html
You will have help in French at the following addresses:
viewforum.php?f=12 ("FR" indicates in the title. example. "FR" Problem index.html")
http://www.phpbb-france.com/communaute/ ... ds-f7.html
http://forums.phpbb-fr.com/mods-de-la-b ... nees-f162/
I am now (and others too;)) on these forums with the same nickname! Note that I translate the knowledge base of Portal Board 3 (knowledge/) and I would put here soon available
regards
In french
Le fichier install.xml en français est disponible sur le portail d'aide francophone de phpbb a l'adresse suivante :
Tu trouveras de l'aide en français sur les adresses suivantes :
viewforum.php?f=12 (Indique juste FR dans le titre de la demande d'aide)
Je suis disponible (et d'autres aussi ) sur ces forums sous ce même pseudo ! A noter que je suis en train de traduire la base de connaissance de Portal Board 3 (knowledge/) et que je la mettrais bientôt à disposition ici ou sur un autre forum
Cordialement
regards
In french
Cordialement
Hallo / Greatings / Salut,
Wirklich leid für die Reaktionszeit / Really sorry 4 the lag of response / Vraiment désolé pour le temps de réponse
I was very busy with other thing ^^ ... but I'm coming back .. thanks 2U !
SeeYaSoon on a other post ...
MultiPadawan
MultiPadawan
thank u uploader...
i just downloaded the file and was trying to just compare it with my previous file.
hardly any error i faced and its really good..
the other good thing is the translation and that is indeed very helpful...
thanks again and hope to see more exciting stuff from you
Files compressed christian louboutin outlet// updating and [French - fr]// adding a Translation// version tar.gz Board3//
