Your Portal Version: 1.0.5
PHP Version: 5
N/A
Read contrib/update from 1.0.5 to 1.0.6
Just wanted to make sure of this before going through. I have a slightly modded 1.0.5 portal installed. I see the contrib folder for the update info from 1.0.5 to current. Do I still just go ahead and copy all the files over and overwrite the existing files and then run install.php?
Updating modified 1.0.5 to 1.0.6
Re: Updating modified 1.0.5 to 1.0.6
Files like portal.php and the additional_block files do not get overwritten, so you shouldn't have any trouble with loosing your modifications. Still, please make a backup of your modified files before updating the Portal.
