Your Portal Version: 3.0.7-PL1
installed the portal files following the install.xml
modified the install.php following the faq section for admin requested at launching install.php
Hi guys,
as i wrote above i have modified and installed all the files following the install.xml guide, then, having troubles on admin request on launching install.php via browser (http://www.coneroforum.it/install_portal/install.php), i have modified the install.php file following the instructions in the faq section.
Now when trying to launch install.php, i display this error:
SQL ERROR [ mysql4 ]
Table 'm20348d1.phpbb_portal_config' doesn't exist [1146]
I didn't found anything in the forum about this error so now i try posting a new argument.
Anybody can help?
mysql error when launching install.php
My Forum:
(Not already open to users, fixing portal issues...
My other sites:
http://ilconero.blogspot.com
http://www.hotelresidenceilconero.it
My other sites:
Re: mysql error when launching install.php
Which version of Board3 Portal are you trying to install? Make sure you are installing Board3 Portal 1.0.5.
ok, that's the problem, i downloaded the board3 1.0.2
sorry, i'l try with 1.0.5
Thanks for fast reply Mark
My Forum:
My other sites:
My other sites:
