I've update 1.0.2 >> 1.0.3 it's OK
After 1.0.3 >> 1.0.5 when I launch /install/index.php > install > next
Check if all files are there ...
Hello
You can see here the message
Erreur générale
SQL ERROR [ mysqli ]
Duplicate entry '4-147' for key 'PRIMARY' [1062]
SQL
INSERT INTO phpbb_acl_roles_data (role_id, auth_option_id, auth_setting) VALUES (4, '147', 1)
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: install/install_install.php
LINE: 258
LINE: 73
CALL: install_install->load_schema()
FILE: install/index.php
LINE: 279
CALL: install_install->main()
LINE: 56
CALL: module->load()
In advance Thank for your Help
