Hi all,
Im really pleased with Board 3 portal and how its turned out.
I just have a few questions that I would really like some help with.
All I want to do is :
1, move the "paypal block" so it can only be seen by registered users. ( and where can I add some text for what it is there donating to, to the re-directed paypal page ?)
2, move the clock from the left side to the right side, so its just above the calendar.
3, move the birthdays block to the right side, so its just below the calendar.
Im usisng CA_Black as my template ( see here http://www.teamgamers.co.uk ).
Can anyone give me any advise, to save me a little time?
It would be much appreciated.
MOVING PARTS OF STANDARD BOARD 3 TO OTHER SIDES
Re: MOVING PARTS OF STANDARD BOARD 3 TO OTHER SIDES
If I were you, I would take a look at this:
Knowledge Base: Moving blocks / change order
And I'll move your topic to the English Board3 Portal Support Forum.
ixl
Topic author - Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Thanks. I put it in the mod section, because I thought the paypal part was a mod as such. However thanks anyway.
Ive read through the suggested help and I appreciate that.
I will try that out. Does anyone know how to restrict the view of a block, ie in my case, the paypal one, so that only registered users see it?
That would be really helpful.
Thanks
IXL
Thanks
IXL
open: root/styles/your style/template/portal/portal_center.html
<!-- IF S_DISPLAY_PAY_C -->
<!-- INCLUDE portal/block/donation.html -->
<!-- ENDIF -->Tip: Replace the preceding line(s) to find with the following lines.
<!-- IF S_USER_LOGGED_IN and not S_IS_BOT -->
<!-- ENDIF -->V.G. archivar
ixl
Hi Archivar,
Your so helpful...
Your so helpful...
ixl
Hi all,
Does anyone know where exactly the text is , so I can edit it, for the paypal block where it states :
I cant see it in either the donations.html or elsewhere...
Any help would be great.
Thanks.
I just wanted to edit it slightly." ..... is a group supplying services with no intention of any monetary profit. Your donations are welcome so that the cost of our server, domain name, etc. can be covered."
Thanks.
Take a look at the language files, especially lang_portal.php.
ixl
Aha !
Thank you so much, yes, I found it
Much appreciated Marc.
IXL
IXL
