CA Black
CA Black
Style: CA Black
Style Version: 1.0.9
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_black.html
Portal Demo: http://area51.mikevil.de/portal.php?style=42
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/ca_black/template/portal/*.*
copy: root/styles/prosilver/template/portal/block/*.*
to: styles/ca_black/template/portal/block/*.*
to: styles/ca_black/theme/portal.css
to: styles/ca_black/theme/images/portal/*.*
open: styles/ca_black/theme/stylesheet.css
open: styles/ca_black/template/overall_header.html
<div class="topnav">
<div id="page-body">
open: styles/ca_black/template/overall_footer.html
<li class="leftside">
open: styles/ca_black/template/portal/_block_config.html
_block_config.html for ca_black
nach: styles/ca_black/template/portal/*.*
kopiere: root/styles/prosilver/template/portal/block/*.*
nach: styles/ca_black/template/portal/block/*.*
nach: styles/ca_black/theme/portal.css
nach: styles/ca_black/theme/images/portal/*.*
öffne: styles/ca_black/theme/stylesheet.css
öffne: styles/ca_black/template/overall_header.html
öffne: styles/ca_black/template/overall_footer.html
öffne: styles/ca_black/template/portal/_block_config.html
ersetze mit: (folge dem Link um zu dem Code zu gelangen)
_block_config.html für ca_black
