CA Orbital
CA Orbital
This config works for both Styles / Diese Konfiguration funktioniert für Styles: ca_orbital
_block_config.html
<!--version $Id: _block_config.html v1.0.5 adapted by: marc1706 $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="block-caption block-caption-header">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div><div class="block-border block-block block-with-caption"><div class="block-content"><div class="block-inner"><div class="block-inner2">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<div class="block-clear"></div></div></div></div><div class="block-footer"><span></span><div></div></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="block-caption block-caption-header"><dl>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></div><div class="block-border block-block block-with-caption"><div class="block-content"><div class="block-inner"><div class="block-inner2">' -->
<!-- DEFINE $C_BLOCK_F_R = '<div class="block-clear"></div></div></div></div><div class="block-footer"><span></span><div></div></div></div>' -->
Open: styles/ca_orbital/theme/portal.css
find:
background-image: url("{T_THEME_PATH}/images/portal/arrowbullet.gif");
replace with:
background-image: url("{T_THEME_PATH}/images/post_show.gif");
