Javascript in Portal only
Rene
Post by Rene »
Your Portal Version: 1.05
Added javascript to overall_header.html
Looked in the portal to see where I might include a javascript
I changed the menu in the portal and have a javascript file that is needed. I added it to overall_header.html in prosilver which is fine except that when I'm not on portal.php, it throws an error since the code is only being used on the portal. It's not a huge deal. Everything still works fine it's just that I get the error in the status bar. Is there any way to add javascript to just the portal? Could I add some "page" that I could include that would add the javascript to the header or is overall_header.html the only place to do this?
thanks for any help or suggestions you might have!! :)
talonos
Portal Specialist
phpBB.com User: talonos
Re: Javascript in Portal only
Post by talonos »
put the code inside of your menu html file instead of your overall_header. that way it will only load when the menu is loaded
