Nothing
Tried unsuccesfully to find code for calculating percentage.
I would like one or two decimals in the percentage.
It look like percentages are alway rounded by truncating the decimal.
In case of a poll with 6/7 options the tot percent get short even of 5 points.
The observer kind of lose faith in the poll.
Please advise how to do it.
Thank you.
Polls Math does not add up properly.
Re: Polls Math does not add up properly.
I found a rounding error a while back and it has still not been fixed.... Here is the thread where I fixed the problem.
Does this help your problem?
viewtopic.php?f=10&t=3057
It did help. Thank You.
Although one decimal place would be more "scientific".
Thanks again.
Thanks again.
