Supernova
Supernova
Style: Supernova
Style-Version: 1.0.0
phpBB-Version: 3.0.7
Board3Portal Version: 1.0.4 / 1.0.5 / 1.0.6
Style Download: http://www.phpbb.com/community/viewtopi ... #p12799583
Portal Screenshot-1-blau:
Portal Screenshot-2-blau:
Portal Screenshot-1-grün:
Portal Screenshot-2-grün:
Portal Screenshot-1-rot:
Portal Screenshot-2-rot:
[+] ENGLISH
Only works without Forum Index.
Since the graphics in supernova / theme / images / blue / ... and in .... / Green / and ... / red /
don't allow it!
Turn off the Forum Index in the ACP Configuration of Board3 Portal.
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/supernova/template/portal/*.*
copy: root/styles/prosilver/template/portal/block/*.*
to: styles/supernova/template/portal/block/*.*
to: styles/supernova/theme/portal.css
to: styles/supernova/theme/images/portal/*.*
open: styles/supernova/theme/stylesheet.css
open: styles/supernova/template/overall_footer.html
open: styles/supernova/template/overall_header.html
<div style="float: left;">
<img src="{T_THEME_PATH}/images/house.png" width="16" height="16" alt="" /><a href="{U_INDEX}">{L_INDEX}</a> &nbsp;
<!-- IF $SN_COLOUR_SWITCHER -->
Tip: This may be a partial find and not the whole line
</div><!-- /colour-block -->
</div><!-- /sn-navbar-content -->
<div id="sn-shadows">
<div class="sn-options <!-- IF SCRIPT_NAME eq 'index' or 'viewforum' -->sn-search-links<!-- ENDIF --><!-- IF SCRIPT_NAME eq 'viewtopic' -->sn-restore-link-size<!-- ENDIF -->">
If you want to show the title of the center blocks as the Supernova forums title change in all center blocks in styles/supernova/template/portal/block/ (not forumlist_search.html, whois_online.html):
{$C_BLOCK_H_L}<dt>
<div class="cat-name" style="margin:-4px 0 -2px 0;"><span>
</dt>{$C_BLOCK_H_R}
</span></div>
Open: styles/supernova/template/portal/block/whois_online.html
    {$C_BLOCK_H_L}<dt><!-- IF U_VIEWONLINE --><a href="{U_VIEWONLINE}">{L_WHO_IS_ONLINE}</a><!-- ELSE -->{L_WHO_IS_ONLINE}<!-- ENDIF --></dt>{$C_BLOCK_H_R}
    {$C_BLOCK_H_L}<dt><div class="cat-name" style="margin:-4px 0 -2px 0;"><!-- IF U_VIEWONLINE --><a href="{U_VIEWONLINE}"><span>{L_WHO_IS_ONLINE}</span></a><!-- ELSE --><span>{L_WHO_IS_ONLINE}</span><!-- ENDIF --></div></dt>{$C_BLOCK_H_R}
[+] DEUTSCH
Funktioniert nur ohne Forum Index.
Da die Grafiken in supernova/theme/image/blue/ …und in …./green/ und in …/red/
das nicht erlauben!
Forum Index ( Forum Liste ) im ACP des Board3 Portals abschalten.
nach: styles/supernova/template/portal/*.*
kopiere: root/styles/prosilver/template/portal/block/*.*
nach: styles/supernova/template/portal/block/*.*
nach: styles/supernova/theme/portal.css
nach: styles/supernova/theme/images/portal/*.*
Öffnen: styles/supernova/theme/stylesheet.css
Öffnen: styles/supernova/template/overall_footer.html
Öffnen: styles/supernova/template/overall_header.html
Wenn Du den Titel in den Center-Blöcken wie die Foren-Titel in Supernova haben möchtest, dann ändere in allen Center-Blöcken in styles/supernova/template/portal/block/ (nicht in forumlist_search.html, whois_online.html):
{$C_BLOCK_H_L}<dt>
</dt>{$C_BLOCK_H_R}
</span></div>
Öffnen: styles/supernova/template/portal/block/whois_online.html
Reason: Änderung für Block whois_online.html hinzugefügt
