eTech
eTech
This config works for both Styles / Diese Konfiguration funktioniert für Styles: eTech
First you need to download and install this Style.
to: styles/eTech/template/portal/*.*
to: styles/eTech/theme/images/portal/*.*
Als erstes musst du das Style downloaden und Installieren.
nach: styles/eTech/template/portal/*.*
nach: styles/eTech/theme/images/portal/*.*
open: styles/etech/template/portal/_block_config.html
replace with:
Öffne: styles/etech/template/portal/_block_config.html
Ersetze mit:
<!--version $Id: _block_config.html v1.0.5 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">&nbsp;<h4>' -->
<!-- DEFINE $LR_BLOCK_H_R = '&nbsp;</h4></div></div></div>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">&nbsp;<h4>' -->
<!-- DEFINE $C_BLOCK_H_R = '&nbsp;</h4></div></div></div>' -->
<!-- DEFINE $C_BLOCK_F_R = '<br style="clear:both" />' -->
viewtopic.php?f=39&t=2638&p=17355&hilit=eTech#p17355
