Style Version: 3.2.9
phpBB Version: 3.0.7-PL1
Board3Portal Version: 1.0.4 / 1.0.5
Style Download: http://demo.phpbb3styles.net/X-Treme
to: styles/X-Treme/template/portal/*.*
to: styles/X-Treme/theme/images/portal/*.*
open: styles/X-Treme/template/breadcrumbs.html
find:Inline find:Code: Select all
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> »Inline add before:Code: Select all
<a href="{U_INDEX}">{L_INDEX}</a>Open: styles/X-Treme/template/overall_header.htmlCode: Select all
find:Add after:Code: Select all
<div id="wrapcentre"> <table width="100%" border="0" cellpadding="0" cellspacing="0"> <tr> <td>find:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->Add before:Code: Select all
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span> <!-- ENDIF -->Add after:Code: Select all
<!-- ENDIF -->find:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->Add after:Code: Select all
<td><img src="{T_THEME_PATH}/images/p_menu/cu_r.png" width="45" height="45" alt="" /></td> <td style="background:url({T_THEME_PATH}/images/p_menu/p_02.png) repeat;" width="20%" height="45"></td> <td><img src="{T_THEME_PATH}/images/p_menu/p_03.png" width="61" height="45" alt="" /></td> </tr> </table>Find:Code: Select all
<!-- ENDIF -->Add before:Code: Select all
<tr> <td> <table style="height:45" border="0" cellpadding="0" cellspacing="0"> <tr>Find:Code: Select all
<!-- IF not S_IS_BOT --> <a href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a> <!-- ENDIF --> </td> <td><img src="{T_THEME_PATH}/images/p_menu/p_13.png" width="61" height="40" alt="" /></td> </tr> </table> </td> </tr>open: styles/X-Treme/template/portal/_block_config.htmlCode: Select all
_block_config.html for X-Treme
Kopiere: root/styles/subsilver2/template/portal/*.*
nach: styles/X-Treme/template/portal/*.*
Kopiere: root/styles/subsilver2/theme/images/portal/*.*
nach: styles/X-Treme/theme/images/portal/*.*
Öffne: styles/X-Treme/template/breadcrumbs.html
Finde:In der Zeile finde:Code: Select all
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> »In der Zeile davor einfügen:Code: Select all
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: styles/X-Treme/template/overall_header.htmlCode: Select all
Finde:Danach einfügen:Code: Select all
<div id="wrapcentre"> <table width="100%" border="0" cellpadding="0" cellspacing="0"> <tr> <td>Finde:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->Davor einfügen:Code: Select all
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span> <!-- ENDIF -->Danach einfügen:Code: Select all
<!-- ENDIF -->Finde:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->Danach einfügen:Code: Select all
<td><img src="{T_THEME_PATH}/images/p_menu/cu_r.png" width="45" height="45" alt="" /></td> <td style="background:url({T_THEME_PATH}/images/p_menu/p_02.png) repeat;" width="20%" height="45"></td> <td><img src="{T_THEME_PATH}/images/p_menu/p_03.png" width="61" height="45" alt="" /></td> </tr> </table>Finde:Code: Select all
<!-- ENDIF -->Davor einfügen:Code: Select all
<tr> <td> <table style="height:45" border="0" cellpadding="0" cellspacing="0"> <tr>Finde:Code: Select all
<!-- IF not S_IS_BOT --> <a href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a> <!-- ENDIF --> </td> <td><img src="{T_THEME_PATH}/images/p_menu/p_13.png" width="61" height="40" alt="" /></td> </tr> </table> </td> </tr>Öffne: styles/X-Treme/template/portal/_block_config.htmlCode: Select all
_block_config.html für X-Treme
