Boardlink: http://www.declutteratyourservice.com
Search topics
N/A
I'm trying to edit the blocks. I am not sure where to go to edit the information to my own.
Thanks
How to edit Blocks
- phpBB.com User: brandy
Re: How to edit Blocks-Please Responde
Please respond. Thank you
First, your portal is either v. 1.0.4 or 1.0.5, the version 1.0.0.RC3 is portalview and MOD to the portal.
Secondly, plz tell what you mean with edit. Is it the block order you want to change ? see Knowledge Base: Moving blocks / change order or is it the contence of one or more blocks you want to edit? You can use the editor nodepad++ (google for it) or do you want help from the forum to edit a block so it match your need ?
you will need to specify more exactly what kind of help you want
/Ghostman
/Ghostman
I would like to edit the content to make it my own. Is there a file that I should go to, for instance to add content?
h
h
I guess it the menu content you want to edit, the board have made a guide for it here Knowledge Base: How to ... add your own menu items Tjeck that out, if you still run into trouble feel free to post again
/Ghostman
/Ghostman
