No user Menue
Moderator: Dyo
kolja
No user Menue
Post by kolja »
I installed the PortalviewMOD and it works
but i tried to ad the user menue (the box with the avatar) like this in the portalview.php:
   if ($portal_config['portal_user_menu'])
      include($phpbb_root_path . 'portal/block/user_menu.' . $phpEx);
But it dont work....
Any idea ?
Grets from Kolja
Re: No user Menue
The user menu should be available in the Portalview MOD from the beginning. Did you change anything in the portal HTML files, e.g. portal_right.html or did you turn off the right column?
kolja
Re: No user Menue
Post by kolja »
No changes, but i turned the rught column off...
Kolja
kolja
Re: No user Menue
Post by kolja »
Ok, i found my mistake!
The user menue was originally on the right side witch i turned off.
After a little jugglicng with the code it works!
Thanks for the help
Kolja
