Attachments Block - pdf attachments not showing
psychoduck
Post by psychoduck »
Your Portal Version: 1.0.5
Boardlink: http://www.pekinheaven.com/portal.php
PHP Version: 5
Checked phpBB3 Posting: Attachment Settings, Manage extensions, Manage extension groups.
Checked Permissions
All set correctly.
In Portal have tried both options in Attachments blocks ie; include/don't include forums
Neither work.
I have several pdf documents posted in seperate posts in a download thread on my forum. I activated the attachment block in my portal, after setting it up and checking all forum and portal attachment block settings.
Whatever I try the block displays No Attachments if set to just the Downloads forum. If all forums are allowed then image attachments show (which I don't want) but when set to downloads only no attachments shows.
Can someone help me please? Thank you.
Re: Attachments Block - pdf attachments not showing
Did you maybe choose to exclude the forum? Did you enable the PDF files in the attachment block config?
What other MODs do you have installed?
psychoduck
No I didnt exclude the forum, and yes I checked pdf in blocks config
I have no other mods installed other than board3portal
I meant there is a list where you can choose what filetype should be displayed. Did you maybe select a few filetypes and forgot to select PDF?
