Your Portal Version: 1.0.5
Boardlink: http://www.ctrl-alt-defeat.com
n/a
n/a
Hey I was wondering how I would go about doing two things.
1. ) Allowing the Welcome Message to accept HTML
2. ) Adding another page to your Portal that is also listed on the main menu navgation.
I've looked and have had no luck with any answers or tutorials on how to do this any help would be much appreciated.
In advanced, thanks.
A few minor modifacation questions.
Re: A few minor modifacation questions.
If you want to have HTML in the welcome block, just turn the BBCodes off (You can do that in the ACP).
You could add the portalview MOD to your custom page. How to add the a new menu item is described in the Knowledge Base.
- phpBB.de User: Evanonian
- phpBB.com User: Evanonian
Wouldn't disable BBCode globally? I want BBCode to exist but I just can't seem to center anything with it.
I'm sorry, you can't activate HTML in the welcome block. That is only possible in the custom block.
Anyhow, if you need to a BBCode to center your text, you might find one here: http://www.phpbb3bbcodes.com/
