Boardlink: http://www.dirttraveler.com/miobib/
PHP Version: 3.07
MySQL Version: 5.0
Fresh board install, only calendar and portal installed. Everything working well, then I changed ucp.php per instructions here...
knowledge/kb_show.php?id=10
Checked functionality, working well, then decided to edit common.php per same instructions at...
knowledge/kb_show.php?id=10 (same thread).
I think I copied the common.php to the root instead of languages\en.....
Board started puking... getting this error message...
Fatal error: Cannot redeclare deregister_globals() (previously declared in /homepages/37/d176353860/htdocs/miobib/common.php:36) in /homepages/37/d176353860/htdocs/miobib/common.php on line 33
Restored both common.php from a file backup I made just hours before.
Restored the ucp.php from same backup.
Restored from PHPbb3 "restore" via ACP.
That didn't help.
That didn't help.
That didn't help.
I simply cannot believe I'm having such trouble (not blaming Board3 Mod, I love this mod and thinks it's great_)
Board down after common.php edit
Re: Board down after common.php edit
Since you just edited a few files, I would recommend asking on phpBB.com for support. I'm not too familiar with such error messages, but they might have come across this several times already.
I did post over there also, but just asking about the backup\restore function.
Thanks for reply.
Thanks for reply.
