Your Portal Version: 1.0.5
Boardlink: http://www.friendzpoint.com
Cant Find entries
i try to find just
I need absolution template changes if someone have please post
i cant find any entry
Absolution Template changes
- phpBB.de User: Khamosh-Saya
- phpBB.com User: Khamosh-Saya
Re: Absolution Template changes
sorry mistake i found it ![Lächeln :)](./images/smilies/icon_e_smile.gif)
Marc my Left and Right Block background color is Blue why?
I don't know, maybe a screenshot might help. But if you edited the files as instructed and used the block config for Absolution, it shouldn't look that way.
marc i didnot still Change mine Style Completly coz i m working mean i m installing Mods
see this screenshot
![Image](http://i43.photobucket.com/albums/e396/jamshed/portalll.jpg)
see this screenshot
If you use the style config you can find here, it will look different.
Thanks marc but last time i change the config file i dont know why it was not changed
well its working fine thanks for help![Lächeln :)](./images/smilies/icon_e_smile.gif)
- phpBB.com User: t-readyroc
I'm also experiencing difficulties. I've attached a screenshot. The files that are missing from the display (arrowbullet, custom-cat-header-/left/right, etc) all exist on the server. I checked out the colours.css file, & the {T_THEME_PATH} variable doesn't seem to be setting correctly. Specifically, when I examine absolution/theme/print.css in a browser (using webdeveloper), the variable is getting set to: ./styles/absolution/theme/images/custom-cat-header.gif
I guess this is why the images aren't showing up? I've gone through all of the steps you've outlined three times now, & even got someone else to watch over my shoulder on the last go-around. Any help would be appreciated.
![Image](http://www.cbl.umces.edu/~burrell/screenshot.png)
Wanted to add that if you go to the board index, the theme loads up without issue, so it seems this is a portal-related problem.
![Image](http://www.cbl.umces.edu/~burrell/screenshot2.png)
Now that I've gone back & looked at it some more, the variable that I questioned above actually is getting set correctly, the problem is that if I inspect that particular element in the first screenshot, the custom-cat-header divs aren't being set anywhere in the code that I can see. I did indeed copy over the _block_config.html code into the prescribed location as well (& do get the information in the ACP).
Browsing directly to the URL of each of these graphical elements (arrowbullet/custom-cat-headers) does show that they are public & available at the correct locations.
