main_menu.html on custom page
aliraj
phpBB.de User: aliraj
phpBB.com User: aliraj
Post by aliraj »
Boardlink: http://shitv.pk
I add a new custom page on my site, i want to show main_menu.html on that custom page, i try to include that file like overhall_header.html But it wont show properly, any help will really apriciated
Re: main_menu.html on custom page
You will have to add this code to the php file of your custom page:
include($phpbb_root_path . 'portal/block/main_menu.' . $phpEx);
aliraj
Post by aliraj »
i did but now all page is blank, below is my custom page php file
* @package phpBB3
* @version $Id$
* @ignore
define('IN_PHPBB', true);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup();
$mode = request_var('mode', '');
		if ($help_ary[1] == '--')
// Lets build a page ...
$template->assign_vars(array(
	'L_BACK_TO_TOP'				=> $user->lang['BACK_TO_TOP'],
	'SWITCH_COLUMN_MANUALLY'	=> (!$found_switch) ? true : false,
page_header($l_title, false);
	'body' => 'europe.html')
make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"));
page_footer();
Please add it before the page_header function.
aliraj
Post by aliraj »
i did but no working, this is my code, please if somthing is wrong paste it with wright code, really thankxa lot
* @package phpBB3
* @version $Id$
* @ignore
$user->setup();
page_footer();
You need to add this:
define('IN_PORTAL', true);
right after:
aliraj
Post by aliraj »
still not working:S
* @package phpBB3
* @version $Id$
* @ignore
$user->setup();
page_footer();
Please turn debug on in your config.php.
aliraj
Post by aliraj »
i turn on debug like this
@define('PHPBB_INSTALLED', true);
@define('DEBUG', true);
@define('DEBUG_EXTRA', true);
but now im getting this error
[phpBB Debug] PHP Notice: in file /europe.php on line 29: Undefined variable: help_ary
[phpBB Debug] PHP Notice: in file /europe.php on line 36: Undefined variable: found_switch
[phpBB Debug] PHP Notice: in file /europe.php on line 39: Undefined variable: l_title
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4326: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3483)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4328: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3483)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4329: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3483)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4330: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3483
i posted above my custom page php file
What do you need this line for:
It's totally useless.
Where is this defined:
And what about $l_title here:
But that doesn't have anything to do with the porta. I recommend you ask about your problems on phpBB.com.
aliraj
Post by aliraj »
sorry i was using wrong php file this is my wright file
$user->setup();
page_header('Europe Azadari');
'body' => 'europe.html',
page_footer();
now im not getting any error but main_menu.html not showing on my custom page
Well you still have to include main_menu.html in your HTML file.
aliraj
Post by aliraj »
i include
in custom page html file, now its showing main_menu but not in proper formate, link below is my custom pagehttp://shiatv.pk/europe.php
aliraj
Post by aliraj »
any news???
I think you still have to include _block_config.html like in portal_body.html.
