error obtain_portal_config() in portal.php
vizant
Post by vizant »
Your Portal Version: 1.0.5RC3
I try to move portal.php from /forums to /
I installed board 3 was fine than i install Galerry that was ok to , after i want to see portal like first page i make like is in knowledge base but get just error
Fatal error: Call to undefined function obtain_portal_config() in /xxxxx/local/home/xxxx/xxxxxxxx.org/portal.php on line 24
i had truoble to find LINE in forums/includes/functions.php
Open /forums/includes/functions.php
'U_PORTAL' => append_sid("{$phpbb_root_path}portal.$phpEx"),
'U_PORTAL' => append_sid("../portal.$phpEx"),
i find something like that and change that maybe there is problem
Can i get any help?
What have to be in root folder .htacces file is just
DirectoryIndex portal.php index.php index.html index.htm or something more
Re: error obtain_portal_config() in portal.php
No, I think the problem is that your portal/includes/functions.php seems to be corrupted. Re-upload the file from the package.
vizant
Post by vizant »
But in guide is
but u want to change
Open /portal/includes/functions.php
anyway i try to find in portal /include/functions.php and forums/include/functions.php and there is no code line like that.
Than i try in your
Board3portal install files and in Upgrade paket phpBB 3.0.7 and i can't find code line
functions.php in includes?
Ok here in Forums/Includes/functions.php
is line
'U_PORTAL'				=> (isset($portal_config['portal_enable']) && $portal_config['portal_enable'] == true) ? append_sid("{$phpbb_root_path}portal.$phpEx") : '',
If is that line do i have to change Full line just that last part your guide is not clear if is only part of the line?
The function that the error message says is missing, is insidet portal/includes/functions.php.
And if your forum root is inside the forums folder, then I'm referring to forums/portal/includes/functions.php
That file is being included by the portal in forums/includes/functions.php.
Check if you have the first edit of includes/functions.php.
