Boardlink: http://www.cotaclan.com
PHP Version: 3.07
Installed a forum, tried to install portals
Read posts, re-read install instructions
I've been trying to install on this portal on my forum but I think I may have "damaged" my directory structure by putting some directories in my root when uploading portal software that shouldn't be there and thereby causing installation problem. I'm only running a Phpbb3 forum with a small landing page right now.
My Current root structure is this:
.hcc.thumbs
_db_backups
adm
cgi
dbboon
forum
includes
install_portal
language
portal
portals <-- added by me where at first I loaded full software too, probably need to delete
stats
styles
My question arises because of the install.xml file and the path to some of the files it references. for instance a file is copied from the root folder in the board3 package to /adm/(etc..).
For instance, the only portal.php I had was in my site root. So this leads me to believe the path is from the site root down.
Also I can't seem to run the last install step. I'm new at this and I have several install files (I'm assuming it's the forum install) but I can't get them to load in IE or fire fox.
thanks for your patients, and help.
Directory structur
- phpBB.de User: flyboy
- phpBB.com User: flyboy
Re: Directory structur
The copy and edit paths are set to the paths of your forum root, i.e. if you forum is inside the forum-folder, you need to copy all the files inside the forum folder.
Thank you!
