PHP Version: phpbb 3.0.7 PL1
Nothing
Change the code into the HTACCESS file (DirectoryIndex portal.php index.php index.html index.htm) into (DirectoryIndex index.php index.html index.htm portal.php)
Hi.
I have a test forum installed on my pc,everything is working great but i just have a little probleem with the redirection after loggin.
This part is alredy done knowledge/kb_show.php?id=10
When i loggin i'm not redirected to the portal.
Redirect to the portal after login is not working.
Redirect to the portal after logout is working.
Change text "Return to the index page" to "Return to the portal page" is working.
Installed MOD's before the portal MOD = Nothing
Thanks in advance for any help.....by the way...great portal
