Error on moving block
Repoman
Post by Repoman »
Your Portal Version: 1.0.5
Boardlink: localhost
Fresh install of Board3 v1.0.5
Search the forum and knowledge base
I tried to move the login-in box and user-menu to the left column by cutting and paste the following code into portal_left.html :
<!-- IF S_DISPLAY_USERMENU -->
		<!-- INCLUDE portal/block/login_box.html -->
		<!-- INCLUDE portal/block/user_menu.html -->
When I purge the cache all works well but when I disable the right column the log-in box and user-menu block disappear from the left column :?:
Anybody who can help me with this problem?
Thanks in advance, Repo[/i]
flexxall
Re: Error on moving block
Post by flexxall »
Found answer here
knowledge/kb_show.php?id=11
Please take a look at the Knowledge Base:
Knowledge Base: Moving blocks / change order
