Your Portal Version: portal_1_0
Nothing
to put a own dump in the database., but i deleted that.
Hello.
I downloaded http://board3.de/viewtopic.php?f=10&t=1061
But how to install?
@/install_portal/install.php
Algemene fout
SQL ERROR [ mysqli ]
Table gaming_24-7.PORTAL_CONFIG_TABLE' doesn't exist [1146]
SQL
SELECT config_value as version FROM PORTAL_CONFIG_TABLE WHERE config_name = 'portal_version' LIMIT 1
BACKTRACE
Portal installation??
Re: Portal installation??
First of, please download version 1.0.5.
Then follow the install instructions (open install.xml with your browser).
Om dit installatie-script te kunnen draaien, moet je de aangepaste bestanden uploaden, vooral /includes/constants.php.
translation:
To run this installation-script you need to download the edited files uploaden, like /includes/constants.php
What to do?
This?:
translation:
What to do?
This?:
Open: .htaccess
Code:Select all
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Code:Select all
<< Hide
Open: viewonline.php
Code:Select all
case 'report':
$location = $user->lang['REPORTING_POST'];
$location_url = append_sid("{$phpbb_root_path}index.$phpEx");
break;
Code:Select all
case 'portal':
$user->add_lang('mods/lang_portal');
$location = $user->lang['VIEWING_PORTAL'];
$location_url = append_sid("{$phpbb_root_path}portal.$phpEx");
break;
<< Hide
Open: includes/constants.php
Code:Select all
// Additional tables
Code:Select all
define('PORTAL_CONFIG_TABLE', $table_prefix . 'portal_config');
<< Hide
Open: includes/functions.php
Code:Select all
// The following assigns all _common_ variables that may be used at any point in a template.
Code:Select all
$user->add_lang(array('mods/lang_portal', 'mods/additional_blocks'));
if(sql_table_exists(PORTAL_CONFIG_TABLE) == true)
<< Hide
Code:Select all
'U_PRIVATEMSGS' => append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&folder=inbox'),
Code:Select all
'U_PORTAL' => (isset($portal_config['portal_enable']) && $portal_config['portal_enable'] == true) ? append_sid("{$phpbb_root_path}portal.$phpEx") : '',
<< Hide
Open: includes/session.php
Code:Select all
if (!empty($_GET['style']) && $auth->acl_get('a_styles') && !defined('ADMIN_START'))
Code:Select all
<< Hide
Open: styles/prosilver/template/overall_header.html
Code:Select all
Code:Select all
<< Hide
Code:Select all
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong>
Code:Select all
Code:Select all
<< Hide
Code:Select all
Code:Select all
<< Hide
Open: styles/prosilver/template/overall_footer.html
Code:Select all
Code:Select all
Code:Select all
<< Hide
Open: styles/prosilver/theme/stylesheet.css
Code:Select all
Code:Select all
- phpBB.de User: arrakis
- phpBB.com User: arrakis
I'm new to this forum
I have installed the portal
http://www.phpbb3portal.com/
but I would put this new portal, which I think is much better
Would any problems installing or updating?
Thanks
Thanks
No, there shouldn't be any issues, we even have update instructions from phpbb3portal 1.2.2 in the contrib folder and the installer will convert your database for Board3 Portal.
It's right
Thanks
Thanks
