Hello,
I would like to download the portal style AeroRed for my forum,
viewtopic.php?style=3&p=19671#p19671
But I find not the link
Would have you the direct link so that I can download it, svp?
Thank you in advance for your help.
Cordially
download the portal style AeroRed ?
Re: download the portal style AeroRed ?
You'll have to do the edits yourself. Just follow the step by step guide.
The probleme it is because this link:
http://www.phpbbhq.com/?p=16
Me sendings in the download of the style forum,
But not of the portal ??
Cordially
Cordially
You don't need to download the style for the portal. You just need the Board3 Portal package and then follow the instructions.
Yes but that asks to copy these files
It is not grave, I copy it all the same in my theme Aerored?
Dsl, I am really noob on this subject there
Cordially
And the style corresponds notCopy: root/styles/prosilver/template/portal/*.*
To: styles/prosilver/template/portal/*.*
Copy: root/styles/prosilver/template/portal/block/*.*
To: styles/prosilver/template/portal/block/*.*
Copy: root/styles/prosilver/theme/portal.css
To: styles/prosilver/theme/portal.css
Copy: root/styles/prosilver/theme/images/portal/*.*
To: styles/prosilver/theme/images/portal/*.*
Cordially
I thought the step by step guide explained it pretty good:
This Guide is written for AeroRed, but it works for AeroBlack, AeroGreen and AeroBlue also. If you want to use this Guide for ..Black ..Green or ..Blue you just have to replace "AeroRed" with the Name of your Style in this Guide.
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/AeroRed/template/portal/*.*
to: styles/AeroRed/theme/images/portal/*.*
open: styles/AeroRed/template/breadcrumbs.html
find:
in-line find:
in-line add after:
open: styles/AeroRed/template/overall_header.html
find:
add before:
find:
add before:
find:
add before:
find:
add after:
open: styles/AeroRed/template/portal/_block_config.html
replace with: (choose your Style)
AeroRed
AeroGreen
AeroBlack
AeroBlue
find:
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
find:
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0">
<td height="24" align="left" style="background:url('{T_THEME_PATH}/images/bottomm.png');">
<div class="buttonwrapper">
<td width="18" style="background:url('{T_THEME_PATH}/images/mr.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/bl.png" width="18" height="18" alt="" /></td>
<td height="18" style="background:url('{T_THEME_PATH}/images/bm.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/br.png" width="18" height="18" alt="" /></td>
<div id="datebar">
<br style="clear: both;" />
AeroRed
AeroGreen
AeroBlack
AeroBlue
Thank you very much, I go re to try
@+ snoooopy
@+ snoooopy
