Your Portal Version: 1.0.5
Boardlink: http://legionofjeepers.com/forum
N/A, new install
None
So I just installed it and it installed OK, just two issues...
- Language in ACP: EDIT: I fixed this, just copied the mods folder from the en folder to the en_us folder...
- Style tweak... if you look at my portal index, the bullets are off, whats up with this?
Thanks
Language and look issue
Re: Language and look issue
Did you edit stylesheet.css?
Did you upload portal.css?
Did you refresh your theme cache in the ACP?
1: YesMarc wrote:Did you edit stylesheet.css?
2: Yes
3: No! I forgot to refresh those things after running the installer, and that was the ticket. Sorry for the dumb question, but thanks!
