Your Portal Version: 1.0.5
Personally, I'm with a doubt. It's about the change in overall_header? For when I edit my forum always reports errors. I wonder if I did not edit it that can cause problems, and that it changes in MOD
Or if someone is disponibilizase to edit the style overall_header melankolia. Thanks
Sorry for my mad english, i'm brazilian
Melankolia style
Re: Melankolia style
I hope this helps:
http://translate.google.de/translate?u= ... =&ie=UTF-8
That overall_header is compatible with 3.0.7?
I don't know, but I think it might help finding the right spots for the edits.
Edited as the post above, but everything was misaligned.
When not overall_header the edict, the portal works perfectly, so I wonder if I can leave the overall as is, without editing it.
ScreenShot:
Thanks
ScreenShot:
Thanks
If you skip the Edits in overall_header.html, you wont be able to disable the phpBB Headermenu, and the Portal Link doesnt show up...
Since the Portal itself will work perfectly, you can skip it for now, and wait until there is a guide for this Style...
I use it without being edited for now. No one could help edit?
Ai is the source without any issue:
<head>
{META}
<!-- IF S_ENABLE_FEEDS -->
<link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" />
<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_TOPICS}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
<link href="{T_THEME_PATH}/web/style.css" rel="stylesheet" type="text/css" media="screen, projection" />
</head>
<div class="outside">
<div class="top-left"></div><div class="top-center"></div><div class="top-right"></div>
<div class="inside">
<div class="notopgap">
<a name="top"></a>
<div id="wrapheader">
<div id="logodesc">
<div id="logo">
<a class="logo" href="{U_INDEX}"><h1><font color="#FFFFFF">{SITENAME}</font></h1><span class="gen"><font color="#FFFFFF">{SITE_DESCRIPTION}</font></span></a>
<td class="row1" height="60px" width="73%">
<p class="breadcrumbs"><a href="{U_INDEX}"><strong><img src="{T_IMAGESET_PATH}/folder.gif" alt="#" />{L_INDEX}</strong></a>
<!-- BEGIN navlinks --> » <strong><strong></strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks -->
<br /><!-- IF TOPIC_TITLE --><!-- IF U_VIEW_TOPIC --><img src="{T_IMAGESET_PATH}/folder2.gif" alt="#" /><a class="topictitle" href="{U_VIEW_TOPIC}">{TOPIC_TITLE}</a><!-- ENDIF --><!-- ENDIF --></p>
<div align="center"> <p><!-- IF U_RESTORE_PERMISSIONS --> <a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF --></p></div>
<td class="row2" height="60px" width="27%"><!-- IF not S_USER_LOGGED_IN and not S_IS_BOT -->
<form method="post" action="{S_LOGIN_ACTION}" style="float:left;position:relative;">
<!-- IF SCRIPT_NAME == 'index' -->
<td width="50%"><span class="genmed">{L_USERNAME}:</span><br /><span class="genmed">{L_PASSWORD}:</span></td>
<td width="50%"><input tabindex="100" class="post" type="text" name="username" size="10" /><br /><input tabindex="101" class="post" type="password" name="password" size="10" /></td>
<td width="50%" nowrap="nowrap"> <!-- IF S_AUTOLOGIN_ENABLED --><span class="genmed">Remember me</span> <input tabindex="102" type="checkbox" class="radio" name="autologin" /><!-- ENDIF --><br /><input tabindex="103" type="submit" class="btnmain" name="login" value="{L_LOGIN}" />
<!-- ELSE --><span class="genmed"><a href="{U_LOGIN_LOGOUT}"><strong>{L_LOGIN_LOGOUT}</strong></a><!-- IF not S_IS_BOT -->
<!-- IF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --> | <a href="{U_REGISTER}"><strong>{L_REGISTER}</strong></a><!-- ENDIF --><!-- ENDIF --></span><!-- ENDIF -->
{S_FORM_TOKEN}
</form>
<td class="genmed">
<!-- IF S_USER_LOGGED_IN -->
<strong>Hi, {S_USERNAME}</strong> <b>(</b><a href="{U_LOGIN_LOGOUT}">{L_LOGOUT}</a><b>)</b><br />
{LAST_VISIT_DATE}<br />
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><!-- ENDIF -->
<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->{PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --><!-- ENDIF --><!-- ENDIF --></td></tr></table></td>
<table class="menu2tb" cellpadding="6" cellspacing="0" border="0" width="100%" align="center" style="border-top-width:0px">
<tr align="center">
<!-- IF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><td class="menu2"> <a href="{U_REGISTER}" >{L_REGISTER}</a></td><!-- ENDIF -->
<td class="menu2"><a href="{U_LOGIN_LOGOUT}" rel="nofollow">{L_LOGIN}</a></td><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><td class="menu2"><a href="{U_SEARCH}"><strong>{L_SEARCH}</strong></a></td>
<td class="menu2"><a href="{U_FAQ}">{L_FAQ}</a></td>
</tr></table>
<tr align="center">
<td class="menu2"><a href="{U_PROFILE}" rel="nofollow">{L_PROFILE}</a></td>
<td class="menu2"><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a></td>
<td class="menu2"><a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></td>
<td class="menu2"><a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a></td>
<td class="menu2"><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a></td>
</tr></table>
<br style="clear: both;" />
Help-me ?
Look at the picture with the overall_header without being edited.
Is working normally with no issues in overall_header, so I only want to respond to the question with a yes or no.
Can I use it without being edited? Since this is apparently working properly.
