Your Portal Version: 1.0.5
Boardlink: http://www.clanoneup.com
PHP Version: 3.0.7
Nothing.
Tried reinstalling the style/portal.
Alright so I downloaded the AcidTech skin version 3.0.7 with that colorize it thing and installed it on my forum and the portal everything works except my new topic, reply buttons and all that don't show up. Tried to purge all the different things that one topic says too.
So I thought the colorize thing messed it up.
Went and downloaded just the regular AcidTech, and still there are no buttons.
What is goin on?
AcidTech - Where are my buttons?
dylanlegit
Re: AcidTech - Where are my buttons?
You need the buttons for your language. As this has nothing to do with the Portal, I'm moving the topic to "General phpBB3 Support".
dylanlegit
I am still unsure of how to solve this, I assumed buttons would actually come with a skin, how am I supposed to track down the right buttons for that skin?
Also this has to be related to the portal. I just RE-INSTALLED subsilver2, checked out my board index, had all my buttons, installed everything for the portal and did the edits, and my buttons disappeared.
You need an imageset for your language. What language do you have on your board and what folders do you have inside the imageset folder of your styles?
dylanlegit
English language, all styles have the EN folder within the imageset..
Alright so I did more searching and when i go to clanoneup.com/styles and click prosliver/imagesets nothing shows up, but yet my ftp shows files being there and I have no buttons on that skin when on the website..
clanoneup.com/styles/subsilver2/imagesets has all buttons also including the EN folder for my language just like prosilver.
On subsilver2 half the buttons show up and the others have text in place which is a link such as the the reply button shows up as "Write Comments" and is a link.
I will try re-installing each style again and adding the portal to it since I have already tried refreshing imagesets/templates etc.. and purge the cache.
