Help with the Revolution Style
CmdBash
Post by CmdBash »
Your Portal Version: 1.0.5
Boardlink: http://www.oillsociety.com/
I tried research other style question in this forum and just could not comprehend the coding that needed to be done to edit such a theme.
I tired the code snippets for some other styles and just had it end with failure.
Hi all, im trying to edit my current style to work with Board3 I am also trying to insert a menu similar to the current Board3Portal theme, I would like that kind of menu.
Re: Help with the Revolution Style
It looks like a normal prosilver based style. Have you tried doing the prosilver edits on your style?
CmdBash
Post by CmdBash »
That did help, I had totally forgotten that step, im going to attempt to edit it so it doesn't look blue as it does not match the style.
I am still trying to figure out the top menu like the Board3Portal theme
"Portal, Board Index" menu.
CmdBash
Post by CmdBash »
I purged and now im missing my menu.html... What did I do here...
I have no idea. What other MODs are you using?
And I also don't know where you would get the menu this style uses. This style isn't up for download.
CmdBash
Post by CmdBash »
Just the Board3 Portal
http://www.phpbb.com/styles/db/index.ph ... ib_id=8885 is there I got the theme, I copied the portal files over from the prosilver folder, edited the header, started looking good but once I did a cache purge I get the menu.html error now....
CmdBash
Post by CmdBash »
So I have to reinstall the forms, im going to build everything back up from step 1.
I wish I had time to do this but im willing to donate $20 to have this style created with a menu bar below the logo.
Im sorry im short like this, Im just frustrated not at Board3, just the lack of time I have to commit to this one.
I'm sorry, but I don't have time either. You might want to ask in a phpBB forum where you can hire people.
Return to “Styles Support”
