Resizing Center Custom Block
Foxy
phpBB.de User: Foxy
phpBB.com User: fujcube
Post by Foxy »
Your Portal Version: 1.0.4
Boardlink: http://www.border-forums.com
Nothing
Nothing
I have just added a banner to my Center Custom Block. It is a linked animated gif banner 468x60 in size. Everything works fine.
If I try to add an identical banner which is 728x90, the banner is not displayed. It will only display the actual code.
Nothing changes apart from the actual size of the banner. I have simply named them both so I can alternate between the two without chnaging the code.
I'm assuming there is a limit on the size of image that can be displayed on the Center Custom Block. If so, how would I change it so I can display the larger banner.
Regards, Foxy
Re: Resizing Center Custom Block
Have you set a maximum width for images in posts in the acp? Board3 Portal uses phpBB's function for browsing BBCode, so that could be your problem. ;)
Foxy
phpBB.de User: Foxy
Post by Foxy »
OMG, why did I not think of that!!!
Problem solved, thank you.
Regards, Foxy
