sliced
sliced
Style: sliced
Style Version: 3.0.6
phpBB Version: 3.0.6
Board3Portal Version: 1.0.4 / 1.0.5
Style Download: http://www.awesomestyles.com/phpbb3-styles/demo/sliced
Portal Demo: http://area51.mikevil.de/portal.php?style=92
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/sliced/template/portal/*.*
to: styles/sliced/theme/images/portal/*.*
open: styles/sliced/template/breadcrumbs.html
find:
			<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
in-line find:
in-line add after:
open: styles/sliced/template/overall_header.html
find:
	<div id="content">
add after:
find:
<br class="clear" /><br />
add after:
open: styles/sliced/template/portal/_block_config.html
_block_config.html for sliced
nach: styles/sliced/template/portal/*.*
nach: styles/sliced/theme/images/portal/*.*
öffne: styles/sliced/template/breadcrumbs.html
finde:
finde in dieser Zeile:
in dieser Zeile danach einfügen:
öffne: styles/sliced/template/overall_header.html
finde:
	<div id="content">
danach einfügen:
finde:
danach einfügen:
öffne: styles/sliced/template/portal/_block_config.html
ersetze mit: (folge dem Link um zum Code zu gelangen)
_block_config.html für sliced
