Your Portal Version: 1.0.5
Boardlink: http://www.jazzcityunited.org
Updated from version 1.0.3 to 1.0.5
When users are not logged in, the portal page is accessible... but when users log in, the portal page becomes blank.
In Internet Explorer, the error that comes up is 500 internal server error.
Users have blank portal
calvin
Re: Users have blank portal
Please provide a demo account, so I can take a look at the issue (via PM please).
Make sure you saved all files as UTF8 without BOM.
Have you checked if all files have been saved as UTF8 without BOM? The normal windows editor is not capable of this, I suggest you use an editor like Notepad++.
calvin
Yes. I did use Notepad++
I am puzzled why portal becomes blank as soon as the user logs in.
calvin
This issue got fixed when I updated to the next version.
I now have the latest update. But yy problem now is after installing NV ADVANCED LAST TOPIC TITLES, the configuration settings in the ACP for portal went missing... but if I have a look at "Module Management", "Portal" is still under ".MODS"
When I tried uninstalling NV ADVANCED LAST TOPIC TITLES, the .MODS tab disappeared.
I've uninstalled and re-installed board3 Portal 3 times already and it still won't appear in the ACP.
Host is using PHP5 and MySQL5
Bischke
open .htaccess and check
http://www.jazzcityunited.org not work
http://www.jazzcityunited.org/portal.php work
http://www.jazzcityunited.org/index.php work
I hope it work
#<IfModule mod_rewrite.c>
#RewriteEngine on
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
DirectoryIndex portal.php index.php index.html index.htmhttp://www.jazzcityunited.org/portal.php work
I hope it work
My Website: http://www.shailos-web.eu
Mods install: phpBB 3.0.10, phpBB Gallery 2.1.4, Board3 Portal 2.0.0b1 and IDLaunch 0.0.5
phpBB Styles: twilightBB 1.0.18
