Your Portal Version: 1.0.4
Boardlink: http://LAN
Search board3 forum
Helo everybody,
I search on forum but I can not find answer for my question. I have forum phpbb3 in Slovenian language. I add board3 portal and some word on portal are in Slovenian language other in English. What should I do or beter where should I translate other words to Slovenian ?
Thank you for any advice.
Best regards
Boris
Language
Re: Language
Slovenian Language isnt available for B3P till now. If you want, you can translate and share it with the Community
Re: Language
No problem, just tell me how, or give me files for translate and I will help how much I can.
Best regards
Boris
Best regards
Boris
Re: Language
Here you will find any information: http://board3.de/viewtopic.php?f=11&t=255
- phpBB.de User: jeanlerymc
- phpBB.com User: jeanlerymc
Re: Language
I believe that Slovenian Language is not yet available for the translation. Probably, you can ask a friend who can translate the words you need to answer those questions. You can also follow the link given in order to be one of those translators so Slovenian will be a language in this site too.
