Unistall
DreadY
Unistall
Post by DreadY »
Boardlink: http://xstudios.org
How can I uninstall this portal?
Re: Unistall
Download the package (if you don't have it anymore) and open install.xml in your browser. Undo every step that is mentioned. After that upload the complete install-folder which is inside the root-folder of the package to your forum root. Browse to install/index.php and click on Uninstall. Follow the steps. After that you can delete the install-folder.
DreadY
Re: Unistall
Post by DreadY »
Thank you very much! And sorry for being a douche and talking like one, I was just nervous my forum was screwed up.
DreadY
Re: Unistall
Post by DreadY »
Prior to running the installation script, you need to upload the edited files, especially /includes/constants.php.
Re: Unistall
Oops, you first have to run the installer and then remove all the edits. Anyhow, just redo the includes/constants.php edit, run the installer (click on Uninstall) and remove the includes/constants.php edit again.
DreadY
Re: Unistall
Post by DreadY »
OK I added
define('PORTAL_CONFIG_TABLE',		$table_prefix . 'portal_config');
In constants, I can now access the Install folder. But there's only the Install button, when I click it I can now click the Proceed to next step, and then get this error:
SQL ERROR [ mysqli ]
Duplicate entry '4-118' for key 'PRIMARY' [1062]
SQL
INSERT INTO phpbb_acl_roles_data (role_id, auth_option_id, auth_setting) VALUES (4, '118', 1)
BACKTRACE
Marc, is there any external way to contact you, like MSN, so you can help me in private?
