Teamspeak 3 Viewer
TheMagicMan
phpBB.com User: TheMagicMan
Teamspeak 3 Viewer
Post by TheMagicMan »
Don't have experience in programming
Anyone working on a Teamspeak 3 Viewer Mod like this one [BETA] Teamspeak Block for Board3 (Version 0.5) or is there anyone who will modify this Mod?
Thanks.
fishi
phpBB.de User: fishi
Re: Teamspeak 3 Viewer
Post by fishi »
Hi I have made for example to my portal also http://board.fishis-community.de/portal.php TeamSpeak 3 on it and lo and behold, it works just fine. You need only in the ACP / Mods / Custom Block's put it under the "Settings for the center's block" your TeamSpeak 3 code: get it from http://www.tsviewer.com. Previously, of course, your TeamSpeak 3 Register here. since you do not need a TS viewer more for your portal
=TQC=Chief
Post by =TQC=Chief »
I use this TSVIEWER system but its not use the phpbb integration .. I want to see guys login in the site use their login name to join the TS3 block ... someone think to convert this TS2 modification in a TS3 integration ?
Hope yesssss ;)
methos-de
Post by methos-de »
Wie schauts denn mit Teamspeak 3 aus gibt´s da schon nen Viewer der auch im Portal geht.
mfg
methos-de
PS: sorry aber ich kann kein Englisch.
Leon M.
Post by Leon M. »
wenn dein TeamSpeak bei TSViewer.com angemeldet ist, kannst du dir einen TSViewer erstellen und den Code im ACP unter der Registerkarte Mods -> Eigener Block, in einem Block einfügen.
Hoffe es war soweit verständlich :)
Leon
ghostman
Post by ghostman »
Try visit
http://www.gilligans-island.de
They have made som php code there can be used to make a portal block
They have both english and german support
