All greetings.
How to do would be to block User Menu be read new photos (number)? As New messages (0).
I should Board3 1.0.4 and phpBB Gallery 1.0.4.
Here's the code:
// + new photo since last visit & you photo number
$ex_fid_ary = array_unique(array_merge(array_keys($auth->acl_getf('!f_read', true)), array_keys($auth->acl_getf('!f_search', true))));
if ($auth->acl_get('m_approve'))
$m_approve_fid_ary = array(-1);
$m_approve_fid_sql = '';
else if ($auth->acl_getf_global('m_approve'))
$m_approve_fid_ary = array_diff(array_keys($auth->acl_getf('!m_approve', true)), $ex_fid_ary);
$m_approve_fid_sql = ' AND (p.post_approved = 1' . ((sizeof($m_approve_fid_ary)) ? ' OR ' . $db->sql_in_set('p.forum_id', $m_approve_fid_ary, true) : '') . ')';
$m_approve_fid_ary = array();
$m_approve_fid_sql = ' AND p.post_approved = 1';
$sql = 'SELECT COUNT(distinct t.image_id) as total
FROM phpbb_gallery_images t
WHERE t.image_time > ' . $user->data['user_lastvisit'] . '
AND t.topic_moved_id = 0
' . str_replace(array('p.', 'post_'), array('t.', 'topic_'), $m_approve_fid_sql) . '
' . ((sizeof($ex_fid_ary)) ? 'AND ' . $db->sql_in_set('t.image_id', $ex_fid_ary, true) : '');
$new_photo_count = (int) $db->sql_fetchfield('total');
// your photo number
$sql = "SELECT user_images
FROM phpbb_gallery_users
WHERE user_id = " . $user->data['user_id'];
$you_photo_count = (int) $db->sql_fetchfield('user_images');
// - new photo since last visit & you photo number
