Cannot find module ./../includes/acp/acp_portal.php
xTz
Post by xTz »
Your Portal Version: 1.0.4
Installed board3 Portal 1.0.4
DROPPED table phpbb_portal_config,
DELETED last 3 things, it created in phpbb_acl_options.
Hi. I have installed board3 Portal, then decided to uninstall, but instead of uninstalling, using the install_uninstall.php script, I just restored the files the way they were, then removed the DB table phpbb_portal_config and the last 3 things, it created in acl_options.. When I try to access the .MODS section in ACP, I got the following message:
What else should I do to clean up the remnants of board3 Portal?
Re: Cannot find module ./../includes/acp/acp_portal.php
You can try this:
Upload the install folder, go to install/index.php and install the Portal.
After that get back to install/index.php and uninstall it.
