Your Portal Version: 1.0.4
PHP Version: 3.06
nothing
looked for the proper page
The static text on the "Link to us" block is written poorly and does not say what i want it to say. Where do you go in the portal block php files to change that static text?
Link to us Block: Change the static text
- phpBB.com User: ReconMarine
Re: Link to us Block: Change the static text
You can find it inside language/en/mods/lang_portal.php:
// link us
'LINK_US' => 'Link to us',
'LINK_US_TXT' => 'Please feel free to link to <strong>%s</strong>. Use the following HTML:',
